So I threw on a set of Edelbrock valve covers from Summit. On the drivers side front cover I have a standard breather cap with the holes on the bottom side. On the passenger side rear cover I have a pcv type breather with the hose going to the carb. The valve covers have factory baffles. On the driver side with the standard breather I have no oil drips. On the passenger side pcv breather, I have oil dripping out of the breather cap from inside. It is not leaking from the gasket in the actual valve cover, but oil is somehow getting up inside the pcv and then drips out slowly onto the manifold. If you look into the bottom of the pcv breather, it isn't just an open hole. It has a portion punched through and the hole is pushed up to make a baffle there also.
So how am I getting oil inside my pcv breather with baffled valve covers AND baffled breather? Everytime I shut the car off it starts drippin out the seams of the breather and smokes everywhere.
