Re: FED question
[Re: Slingshot383]
#1529344
11/06/13 02:19 PM
11/06/13 02:19 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Depending on how wide the chassis is, you might need to massage the Ultrabell to fit, you will have to use an indexable starter to fit in the space alloted, and you may have to massage the oil pump assembly. Just take a lot of measurements and pictures. You do have a dragster pan on your BB, if not, you will need one.
Hey Larry, just to clarify, the PG UltraBell(which has to be used with an adapter) will usually fit, the Mopar U-Bell will have to have quite a bit of the starter flange/pocket milled down. I can take some pics tonight, also dragster pans are usually meant for RED's and can be at least 6"X6" deep, 12+ quarts. The FED's almost always need a shallow F/C style pan.
