YES I HAVE RUN MANY OF MY CARS ON ACETY GAS, BUT THE CYL OF ACETONE IS TOO UNSTABLE TO BE RIDING ROUND WITH IT, EVEN FOR ME.
tHERE IS LOADS OF POWER IN IT.
THE cALCIUM CARBIDE IS MORE TAME TILL THE WATER HITS IT AND YES IT STINKS AND LEAVES A PAST RESIDUE WHICH CAN BE DIMPED OUT EVERY FILL UP AND ITS IN FACT A ECO FRIENDLY FERTILIZER
IF YOU ADD THE OXYGEN YOU GET HUGE POWER RELEASES JUST NOT SO MUCH THAT YOU MAKE A CYL TEMP OF 5000 DEG AND WELD THE RINGS.
WORK WILL CONTINUE. NOW WHOSE GOT A LEAD ON CHEAP SUPPLY OF THE STUFF (80 BUCKS)IS NOT WHAT INDUSTRIAL HOUSES PAY TO FILL YOUR WELDING TANKS
