Matt you can run it fine...just a couple of sensors are not compatible....just get the later harness...and the later 5.7 Cam and crank sensors.
The guys at MSD don't know sh1t unfo.
The other issue is the tune that is provided by MSD..follow these two links and learn all about both issues........
http://moparskunkwerks.wordpress.com/27-dec-12-making-sense-of-the-sensors/
http://www.forabodiesonly.com/mopar/showthread.php?t=254123
Thanks for advice from someone with hands on and the links.
Getting old just means you were smarter than some and luckier than others.
