5.9 r/t head if your looking for more go
All factory 5.2 and 5.9 magnum heads are the same for all intents and purposes, a couple different casting numbers but they all function close enough to the same that you can mix and match with no issues. A 5.9 R/T has the same exact heads as any other 5.9 of the same year.
