I love that switch panel. The problem is the touch panel switches. I think they are sexy. But in a race car, when stuff hits the fan, (such as throttle hangs wide open or brakes fail) you have to have switches you can take a bat at with your hand and turn off without looking at them or thinking about it. (Don't ask me how I know.) Don't use this switch panel in a race car.
You can program the switches with dip switches so that it will turn everything off when the Ignition switch is turned off. Mine is that way other than the Fan & Water pump stays on...
Still not the feel you want, but it is a option.
