Will I be able to retain my 35 splines axles from my 8 3/4 ?
I had Strange 35 spline race axles special made to work with the stock A body 8 3/4 housing with the strange 35 spline 8 3/4 spool, I twisted that rascal(houusing) up horribly with no back brace. I swapped the axles over to the truck Dana 60 I had narrowed and I had to cut about 3/8 inch off the end of one axle, so yes you can reuse your 35 Spline axles in the Dana 60 with the 35 spline Strange, Dutchmen, Yukon and many other spools Make sure and check for end play, don't let the axles butt in the center The exception might be the Mark Williams 35 spline spool with thier different axle and spool teeth angle, 30 degree versus maybe 45 degree angles, not sure which one is which
