The door lock buttons operate switches in the doors that operate solenoids connected to the door latches. There is relay inside the passenger kick panel as well.
You'd want the lock rods and clips, solenoids, switches and wiring (or at least the connectors) and the relay.
I don't know if it will all bolt in a '71, but since they're both B bodies it just might.
