How much filtering performance is enough?
CS ....just how much is REALLY NEEDED .... uNless your motor is coming apart ? ... have you ever cut apart a filter .... after one ...two ...three ...even TEN oil changes(after using the same filter) ?
One could buy the orange can from the big box store for four bucks and the engine will likely outlast the vehicle.
However, the question was not what oil filter will get me by. The question by the OP is "need the best filter"?
I answered the question.
