Can you remove the added balance weight from a converter for an external balance application, and use it behind an internal balance engine? I don't know why not, but I've been wrong before.
The factory added the needed balance weight onto the converter originally the trick is to get it off the converter with the weight intact weighing what it weighed before removal
