Its in a 66 coronet.
3500lbs
499. Eagle crank, rods and wiseco pistons. 12.5 to 1. Indy SR heads max wedge ports. Indy flat tappet cam ( around 617/623 lift. i cant remember right now). 4.56 gear dana. 8 inch converter from PTC.
You call that a mild build ? Nice looking Coronet by the way. Ron
