I'm using 2" supercomps... easy fit and easy to get to the plugs. I had a set of cheapo 1 3/4" on it before and these things drop in compaired. I was going to use the hooker 1 7/8 but after trying one side I hung them back on the wall. The 2" are 2 piece so they install pretty easy. No issues w/ plug wires either. I only use one plug jacket. I have stage VI heads not sure how'd they'd work w/ e-heads..
Pretty sure stage VI's ahve staright plugs , his issue is the angle plugs on the eddies , only TTi has addresses angle plugs , just about everything else is centered around people still running 906's
