porch and patio with diamond plate under tires
wood has to be clean
Where the tires sit will eventually wear through the paint. The diamond plate will also help keep the tires from sliding around. Doing the whole track where the tires will roll is even better, but it gets expensive. Local sheetmetal shop can sheer lengths & widths as needed.
