Re: 66 Belvedere II - Oil Filter
[Re: edl]
#1507899
09/27/13 08:53 AM
09/27/13 08:53 AM
Posts: 75,110 A Banana Republic near you.
JohnRR
Unless you are totally anal about original numbers, but you can't be considering you have an electric fuel pump, any good (non fram) filter will be fine. Hastings has been around for longer than your car has. They have a good rep.
on the original numbers thing, i am trying to keep it as original as i can - so taking the electric fuel pump as an example, that is the way the car came - if it weren't there, i wouldn't have added it - but i am not racing to undo do it and put it back to bone stock - little, by little - on the brakes, i just rebuilt them and keep them drums all the way around just the way they came - with the master cylinder, i put the the 67 mc in because it is 2 stage and so for safety if i lose one set of brakes i have the other - that is kind of the philosophy - in terms of what i got, the car is pretty much stock (but with the odd exception (like the fuel pump))
You aren't going to find an original filter unless you look on places like ebay , there you may run across a 40 yr old filter for $1500,. Me , the last thing I would do is put a 40 yr old filter on anything that is going to be running.
