I did buy that '86 Larry and the 360 engine was a runner. The problem was that the PO changed the fuel pump and forgot to put a clamp on the inlet side hose!! The engine would run for a few minutes, start sucking air and quit. I trailered it home and started and drove it off the trailer. I have everything to make it run except the driveshaft, a Built 440, Pat Blais race 727, two different converters to try, a narrowed Dana 60 with 4.10s , nice wheels & tires, etc. etc. I cut the floor out of the back to mount the aluminum fuel cell today. Once I get the back done, I will turn the truck around and back it into the garage so that I can put in the new van pocketed control arms and fill the huge holes in the fire wall. Just some assembly required LOL
