maybe I do have the wrong plug, but this plug(ngk 5671a-7) has stayed the cleanest and looked the best out of the other dozen plugs i'v tried. does a flat top piston generally require different timing than a dish piston? I have a friend that has a 440 small block with chapman w7 heads and has found that 38* works best for him with 11.8 comp.
