Also the coulum plug has been cut off and spliced with barrels, not sure I have enough wire to cut off the barrels and solder all the wires before re connecting them. Anyone know if the ron francis kit comes with all the plugs needed? I'd like to get a new main plug for the back of the dash also. I get all the dash lights working, clean all contacts and tighten everything I can find but after a few bumps they go back out and I'm tired of all that work just to have them go out again three days later. If the kit comes with everything needed and all new plugs then it sounds like it would be worth it to re wire and be done with it once and for all. Thanks, Clay
