It might be different car to car depending on what your setup is. For instance, your water pump, and how hard it is being turned. There are water pumps that move more water (i.e. pump harder sucking the hose closed) than others. Also, if you are spinning more RPM, it is going to spin it harder/faster.
Some might be able to get away with no coils while others need them.
383, Hemi 4-Speed, AlterKtion, D60
