Be nice to know what you are putting together.
Oh yeah, ha!
I'm building a raised deck 496" wedge, with a D1SC Procharger for my '67 Dart. Had a Procharged 440 in it, that was built entirely wrong, and fairly mild. I managed to salvage the block and intake manifold, but that's it. The rest is new. Went with a K1 4.150" crank, Scat Chevy H-beams, coated Diamond dish pistons (which I spent way more on than I probably should have lol). Just going with Edelbrock RPM heads, but I'm putting 2.19's in the intake and doing a little bowl work to them. Blow through carb from Kevin at CSU. I'm at 6000' so I'll be down on power, but it should do OK on pump gas at 8-10psi of boost.
