Re: 1968 + 1970 Charger Dash Question...
[Re: hemi68charger]
#1492265
08/29/13 09:28 AM
08/29/13 09:28 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
It'll pretty much work, but you will have no flasher/emergency switch. In the '68, it was in the instrument cluster under the dimmer switch. Not sure what it is worth, but it will definitely be worth more than a '68/69... I doubt you will find a situation where you can get a complete swap, but best of luck in trying. You definitely should be able to sell it and then come up with the funds to get yourself a '68/'69 Rallye/Charger dash. That '70 looks to be in pretty nice original condition to be honest. Also, was the VIN transferred from the original dash to this '70?
I would throw this picture in the for sale section or trade and see what happens...
Cheers,
what he said, I'd try and sell that complete and buy the correct dash. I think some of the harness is going to be different as well. In 70 the ingnition switch is in the column. I'm guessing that dash is from an S/E???
