I will be there just not sure the car will be. I have the back glass coming out so I can fix a few pin holes around rubber. I'm not sure if I will have that fixed in time. I only live about 10-15 minutes from there.
Regarding the window, Its not going to rain, and with those tires you should be able to out run the rain.
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
