If a standard volume pump can get you adequate hot running oil pressure (eg 55-60 psi for a hot street engine) and adequate hot idle oil pressure (I like at least 20 psi) that's the way to go. Bigger rotors just push more oil past the bypass, use power and generate heat. Usually in a healthy engine, meeting the idle requirement is toughest.
