Okay here I go:
Carter AVS 800
Edelbrock DP4B ported dual plane intake
Ported Stealth heads with Harland Roller 1.5
Solid street roller cam @.50= 236 intake and 243 exhaust, .552 gross valve lift. Lash at .014th intake .016th exhaust
Valves 2.14" intake 1.81" exhaust
Flow rates
intake
.500 - 285
.550 - 289
exhaust
.500 - 217
.550 - 223
400 block with stroker kit to 499 cubes, compression 11:1
3.91 rear gear with 4 speed
Msd box
3900 lbs weight
mechanical edelbrock fuel pump
stock manifolds with 2 1/2 x pipe exhaust
manifold vacuum at idle 14 inches
I hope I did not miss anything. It runs and idles like a clock.
At 1000 rpm timing is 17 degrees at 1500 rpm timing is 25 degrees, never checked when it starts to advance somewhere between 1000-1500 rpm.
