I had one in my 78.It was in another Ram that I bought for parts.I plowed and put at least 40K on the setup.Only problem I had was I snapped some bolts in the frt hub once.I plowed and drove it every day fro at least 5 years.Rocky
I used to run a part time kit in my 79 RC with a 203 full time xfer, worked fine for me for yrs.
i also installed the chainsaver from milemarker, that would let you adjust the slop out of the xfer chain when it got worn and wanted to slip. that saved my old worn 203 for a long time.
I used the milemarker M&M locking hubs with brass dails up front that were trouble free.
