OK, I'll let you know. Right now it looks like 1.24" torsion bars without hex offset, because otherwise the car sits too high with such stiff springs.
On the rear, it should be 6 or 7 leafs to get the desired spring rate. Spring arch needs also to be factored in, as well as standars eye or reverse eye option.
Does any of you have experiences about mounting reverse eye srpings and getting rid of the necessary 2" lowering block ?
