another
Take the panel with you to the auto paint store, and ask them to match it in an SEM dye. Make sure you buy the correct plastic primer to go with it.
What he said. And when you go, pick up some POR Marine Clean. Clean all your parts in a 10:1 solution of that stuff (WEAR GLOVES) and it will strip all the old oil/armorall and dirt right off. Spray with the SEM Surface Prep and follow up with the top coat and it will look good as new. Actually BETTER cause it will all match!!! Best way to go about it after my experience is with a quart mixed to the right color and a detail gun. the stuff is easy to shoot and will make you look like a pro.
I’m listening.
