You would think in 90 degree heat you would slow down. My throttle stop bolt is turned in all the way. Still 9.42. Never thought I'd have so much trouble slowing it down.
Doug
It can be a bit{h to slow a car down... put in a longer
bolt... I lower the launch RPM and the shift points also
