Quote: Put a layer of Good silicone sealer on the outside whole plug they will not come out if you let it totally setup. And if you dojn't have to hit them hard get another plug DO NOT USE THE RUBBER BOLT IN TYPE
Thanks Paul,I don't use RUBBERS
HEMI-ITIS has no cure. My condition is fully BLOWN!!
