You wouldn't have the battery in wrong would you ? lay a screwdriver up against the back bearing of the alt and see if there is a magnetic field there. if the driver don't "stick" to the back of the alt , its not charging even though the alt may be good . if the batt was installed reversed u will have some electric issues including fried wires etc.
