Use a 360magnum flexplate with the weight on it,remove any weights from the 3.9 converter. add 2 injector wires(or a harness if you like) ,and cpu. Dakota oil pan and pick up tube.
what do you mean "add 2 injector wires"?. do you mean a dakota oil pan for a 360? thanks guys.
