if those tubes are glowing at idle, I would say too lean. you will need to remove the front carb to get to where you can remove the float bowl on the center carb.
glowing like that I would jump 2 to maybe 4 jet sizes larger.
glowing while driving it could be a lean condition or to much timing.
more info is needed..
I am truckless..
