or on the intake manifold?
That one. Coolant approaching the stat is always the hottest (it just came from the eng innards). Hot coolant is flowing from the front of each head laterally into the intake toward the center stat housing. The eng nipple in close proximity to the housing will be the one going to the heater inlet
