myself I would not be comfortable with used pistons but I see them regularly for sale. The machine shop has to have the fixture that goes in & supports the bottom side of the rod small end other wise the bottom of the piston would likely be damaged when pressing the pin with everything bearing down on the bottom( the side actually) of the piston
