I believe the old relays are a function of current generating heat to make them work not a given time.
If that is correct I would try one relay and see how
much time you get with that. I bought a new relay
for my A body last fall so I know they are readily available.
As for the wiring, should be fairly straight forward. A wiring diagram will give you the pass
through circuit.
