So 7400 all together or 5000 to 6000 with victor heads.
Check the rings for butting it's such a low buck build probably not balanced and may have put + .060 rings in maybe that's whats pulling the pistons apart.
cross hatching still on the cylinder walls. did it have steel or composition gaskets.
