I was thing a hydraulic roller would be quieter too, but it seems to be just about as loud as a solid roller, or maybe I'm just hearing the roller rocker arms, rollerized timing gear, and roller thrust bushing?
I think a rev-kit where the springs press on the top of the lifter body would help if you want to run high RPM with a hydraulic cam?
