I actually don't plan on using that housing,as I will do the same as I did on the cuda and pull a dana out of a truck and adapt it. I'm going to narrow it a little also. I still have the option of using the original front spring mounts as they're still there so if I use 3 link or 4 link I'm essentially not moving things that far inboard and as for the 28" overall i can still fab up wider mounting points for the coilovers. I'm starting to think it will work.
