I got a dead 74 duster. It wont do anything when I turn the key, but will crank on the starter relay but wont fire there know lights either. It started fine until I was fooling with the dash cluster and forgot to unhook the battery. And the 2 wires that hook up behind the amp meter touched each other and blew the fusible link. I replaced that with a 20amp link from oriellys and still wont do anything. The only thing the link changed was the oil light on the cluster came on. Im not getting any spark from the coil. Is it still the fusible link or Is there something else I could have fried.
