I've got a '71 GTX with a stock reproduction antenna.
The base plate for it sits flush against the fender..but..the hole in the top of the fender is on an angle due to the fender being roundish, so my antenna is leaning awkwardly away from the car.
Does the antenna bend at the very base above the bezel?
Did they used to have shims that I'm not seeing?
Thank you.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
