Yes, I agree that it is a bad idea to cook a coil by leaving the power to it on. I'm not sure how you have everything wired but relays from keyed ignition power are your friend. I had a 54 dodge pickup that I wired a separate switch for coil +12v. Sucked because it was possible to leave it on and take the key out and have that problem like you. Sorry for the bad luck man!
