I love your truck. What are the engine specs and what trans is in there?
Not my truck but I helped in the build. It's a 2004 Ram Rumble Bee. Sharadon Performance built 6.1 based 419, 9.5:1 Ross pistons, 4.05" Callis crank and rods, ARP main and head studs, ported and polished 5.7 heads with 2.05" int 1.57" exh valves, Indy Modman intake manifold with a 90mm throttle body. The transmission is a Viper T56.
Jerry Williams.
