I tapped my block and put in an allen head pipe plug, no problem. Used the Milodon deep pan and their flexible dipstick.
Thanks I did the same. The hole in the block is already 'drilled' out to 1/8"npt tap size, I didn't have to drill it, just run the tap in. Pretty easy.
