ok, got it in. Now, the shop manual says to put on the rotor and bearings, then the thrust washer and adjusting nut, then tighten the adjusting nut to 90 ft/lbs, then back off enought to fit cotter pin in. The end result should be zero to .003" end play.
Not a factory shop manual is it?
Should be 90 INCH/pounds, typo in the manual. Ran into that one a long time ago.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
