Quote: I'll bet there is a vaccum leak at the throttle shaft's. Spray carb cleaner around the throttle shafts with it idling fully warmed up and i bet the idle smooths out.
There are "very" few that don't leak some at the throttle shaft,idle mixture adjustment will take care of that.
