I am installing a trans crossmember frame rail in a rotting 73 CUDA'.. Need a measurement for correct placement..Can someone with a cuda measure from the back of the torsion bar mount sleeve that is welded to your K-member..measureing to the front of the frame rail for the trans.. I am trying to make sure the trans mount lines up correctly..Thanks for any help
