with the back seat out do you have a straight line of sight to the bolts for the catch? If so several long 3/8 extensions/a swivel socket & some electrical tape around the swivel to keep the socket in line might do the trick. Never drilled one but it's doable (patience & a sharp quality bit). EDIT Shoozy nailed it, either a kid or a dwarf or a midget whatever is available
