Simply unplug it and plug it back in again. This might be a quick "on the road" fix for you and has worked for me MANY times. I assume the slightest bit of green stuff type corrosion can mess up the signal. Sometimes just striking a new connection can clear it up. Sometimes you have to use spray electric parts cleaner and dielectric grease to get it working properly again.
