wouldnt be uncommon for warpage on the top of the tank and leak around the fuel pump module...also check all the vacumn hoses to the purge valve, the ldp, canister etc any small crack can turn on the mil. also not knowing where you are if you have a rust hole in the filler tube...thats pretty common in these parts
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
