just an fyi for carb tuners like me I think the x oring loose there elasticity and sealing power causing tuning problem.
Rubber O rings for 4" fuel delivery hoses shrink due to ethanol. It may rot the new O rings.
Yah I understand that but Ill now be able to search for some oring that are resistant to fuel now that I know the issue and size I need. Have any suggestion to what will hold up as it seems even my rebuild kit ones didnt hold up as well as I thought. Will the hydraulic hose ones that nacho used work? Or is there a certain type of rubber I should be looking for?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
