MJ = (plant) Topeka, KS Goodyear plant U2 = (size) F70-15 DXA = (type) nylon cord (SPEEDWAY) white stripe 411 = (date) 41st week of '71
This post has explained the plant and date for Goodyear tires well. What is missing is a chart of codes for the size and type of tire. If someone has such a chart, would you mind adding it to this post? Thanks.
Quote: What do you have? I've been collecting data to see if there is a way to reverse engineer any info from it.
..... but I'd need numerous examples to prove the "educated guesses" - one tire I've been looking for proof of is a Firestone Wide Oval pre-1970 that is fiberglass-belted.
